New Member
Oct 20, 2026 1:26 AM UTC
Sending clean audio from a conference PA system to Zoom on an iPad for simultaneous interpretation
provide simultaneous interpretation for in-person conferences using Zoom's language interpretation feature. At each venue, I need to send the speaker's audio directly from the PA system or wireless microphone receiver to an iPad connected to Zoom, so that Zoom receives a clean audio feed instead of picking up ambient room noise through the iPad's built-in microphone.
I've used an original IK Multimedia iRig connected to the sound system's headphone output, and this setup used to work. Recently, however, Zoom has been picking up the iPad's internal microphone instead of the external audio.
I also have a Behringer UCA222 USB audio interface and an XLR-to-RCA cable. The iPad may have either a Lightning or USB-C connector, depending on the venue.
My questions:
  • What is the simplest, most reliable way to feed the PA system's audio directly into Zoom on an iPad?
  • Does Zoom on iPad reliably recognize USB audio interfaces such as the Behringer UCA222?
  • Would it be better to connect directly to the wireless microphone receiver or to an appropriate output on the venue's mixer?
  • Is there a known limitation or setting in Zoom for iPad that could explain why it is using the built-in microphone instead of the external input?
I need a practical, low-cost solution that can be set up independently at two venues hosting events simultaneously. Ideally, I'd like to use equipment I already own before buying anything else.
Thank you for any suggestions or tested setups!
    bstrelko
    Nov 5, 2026 8:01 PM UTC
    You are rolling the dice using a mobile OS. Go for a desktop (laptop) Zoom client + audio interface or Zoom Room client + interface, where this is much more of an expected use case that the respective Zoom application will give visibility into.
    External video and audio peripherals with iPads has always teetered between various degrees of ‘functional’, but it’s definitely not something I’d lean on for a high-impact event.
    If you insist on using an iPad, class-compliant USB-audio devices will be your best friend. You are ultimately at the mercy of both the OS and the lesser-maintained iPadOS Zoom build, as there is no ‘certified’ hardware for this use case.
