Send number of Zoom participants to OBS: Is there a friendly way? | Community
  • June 23, 2022
  • 42 views
Hi, all!
During my meetings I receive virtual camera from OBS to Zoom, and send the Zoom audio to OBS to live streaming on Youtube.
On the screen can be viewed the numbers of Youtube Participants using a web source on OBS.
I'm able to show the number of Zoom participants using a window capture on OBS.
This way is not so good because when resizing the window of Zoom result in a mess on OBS screen, of course.
Has sombody some better idea to workaround this?
Is there another friendly way to do it: send the number of Zoom Meeting Participants to be shown on OBS?
Sorry for my bad English.
Thanks in advance!
    June 24, 2022
    Hey, @Rossini_Neto  -- I got your concept just fine.
    I think you are currently grabbing your participant count from here:
    Have you considered trying to get it from the Participant window here?
    That's the only other way I know using OBS.  There might be something in an API, or a way to manipulate data within ZoomOSC but those would be fairly technical to implement.
