Mar 16, 2026 10:41 PM UTC
Screen sharing audio and video disruption and delay
I got a new company laptop and am not able to screen share without the video and audio being delayed. I have turned off my camera so I am not on video and it still happens.  I was using a different work laptop for a couple of years, with the same internet connection, but now when this happens I get a temporary pop up that says “your internet connection is unstable”.  What settings, etc. could be causing this disruption? I just added additional RAM and same experience.
Suggestions?
    ExpertswhoJohn
    Mar 17, 2026 9:54 AM UTC
    hi ​@Linda Harper
    There is delays on Zoom, but as we  only see the world from our machine, we do not percieve it.
    If you have a poor connection, or poor performance then this can make things worse.
    Are you using a contested wifi or far from the router. Different laptops have different perofrmace on wifi
    Screen sharing is also a hard to do activity for zoom and will also reduce performance.
    Running other apps while using zoom reduced performance.
    All the best
    John Drinkwater
    Zoom Developer Champion
    https://lordzoom.com/go/hub
