Response of zoom AI is not relevant with my info. | Community
  • April 25, 2024
  • 0 replies
  • 31 views
I'm using Zoom AI Companion solution. However, It generate response regardless to my situation. Is it possible to make response regarding to my data? For example, a sentense which I use frequently also called 'template' should be reflected to response AI generate. I want to get response which is relevant to my past data. it is called ..... Tuning?
