Nov 5, 2026 9:00 PM UTC
Reduction in quality when using background effects
I installed Zoom (on Windows 10) early in June 2026 but according to Control Panel the last install was just over a month ago on 25th Sept (so presumably Zoom updates itself automatically?)
Around September I noticed that if I have any background selected and I physically move, the movement (i.e. me) is very jerky and blurry. I don’t remember this problem when I first installed Zoom in June. Is anyone else aware of this and is it fixable?
    New Member
    Nov 5, 2026 9:35 PM UTC
    Same here! When I have a certain background for a specific group, my face is blurry, and everyone else in the group has the same background, and their faces are clear.
    New Member
    Nov 5, 2026 9:39 PM UTC
    I've had the same problem since I uploaded a background for a group I facilitate. Everyone else with the same background has a clear face.
    johne53Author
    Nov 8, 2026 9:03 AM UTC
    If this isn’t fixable is there some way I could uninstall Zoom and re-install the older version from June that worked? I’ve still got the installer that I downloaded in June if that’ll help.
    harrietsloane
    Nov 8, 2026 9:17 AM UTC
    I've seen this after updates too, and it usually comes down to how much work the background effect is asking your computer to do. Try turning off HD video and hardware acceleration for a test call, and make sure your lighting is even — that helps Zoom separate you from the background more smoothly. I'd stick with the latest version rather than going back to an older one, as a clean reinstall of the current version often clears up the glitch.
    johne53Author
    Nov 8, 2026 9:55 AM UTC
    Thanks Harriet. Is hardware acceleration a setting within Zoom itself or somewhere else? I’ve just disabled HD video within Zoom but that didn’t help 😥
    johne53Author
    Nov 8, 2026 11:23 AM UTC
    This morning the installed Zoom version here was 7.1.0 (48550) so I uninstalled Zoom and re-installed version 7.0.5 (38856) from June. And to my surprise, the issue is still present. It’s nowhere near as bad but it is still present.
    I wonder if it could be an issue with my webcam? It’s made by Emeet although the driver hasn’t changed since June and previously it’d always worked fine.
    If no-one here’s got any ideas I’ll try updating the Emeet driver and see if that helps.
    johne53Author
    Nov 11, 2026 10:38 AM UTC
    Right, I’ve been in touch with Emeet and carried out their tests and it’s definitely not the webcam. Good news is that it’s very bright sunshine here today and it’s not quite as bad in bright light. In fact it doesn’t happen at all with background effects disabled but as soon as I enable one, (even just the blur effect) back comes the blurry movement and the jerkiness.
    Disabling HD is better but not much. I’d like to try Harriet’s suggestion about disabling hardware acceleration and a few days ago I accidentally stumbled on a hardware acceleration setting in the Zoom app but I can’t seem to find it any more.
    It was something to do with Advanced video settings somewhere but I can’t track it down 😥
    [Edit...] I found it by clicking on Settings (after clicking on my name icon) and then typing Advanced - but guess what..?
    If I use my hands to cover my hair the problem almost disappears!!
