Apr 20, 2024 8:40 PM UTC
Recording with two hosts showing at once and not participants- using powerpoint
Hello, I am needing to record a presentation done using PowerPoint on zoom. There will be a co-host and I need both host and co-host videos (or rather thumbnails) to be shown on the side. However I cannot have any of the participants thumbnails showing at the same time in the recording. This is especially important for confidentialitya s this will be recorded and shared. So no other participants showing bu the host and co-host and the powerpoint presentation as the main screen. Can anyone help? Ive done everything from pinning to spotlighting t o changing my setting in the backend, nothing is working and my $250 a year to zoom still makes me ineligible for help...;-/
Humashankar
Apr 20, 2024 9:47 PM UTC
Hi @CharlieH
You're right,
unchecked 'Automatically adjust microphone volume' sometimes doesn't prevent Zoom from boosting your mic gain, try other possibilities like - Disable Exclusive Mode / Conflicting Settings by choosing "Properties." Under the "Levels" tab to ensure the microphone volume is set to your preference and not boosted
Warm Regards
CharlieHAuthor
Apr 20, 2024 11:01 PM UTC
Think you may be replying to a different post.  My question wasn’t about a microphone or sound
Humashankar
Apr 22, 2024 2:36 AM UTC
Regret for the inconvenience caused, yes my solution is for a different use case.
CharlieHAuthor
Apr 22, 2024 2:53 AM UTC
No worries. Any solutions for my problem?
CharlieHAuthor
Anyone able to help?
