Recording problem | Community
Recording problem
Hi  I have had to switch to a  USB connected YETI microphone. I checked it worked and that the speakers worked when i opened up the meeting.  I also enabled it in settings.  However, when i played the recording back, there was no sound.  I have never had this problem using the built in microphone jack.  What might the problem be? Have spent hours trying to work it out!! Thanks for any advice
    Hey @MarianB your issue maybe related to "Blue Yeti microphone not working on MacOS Monterey" Checkout the thread and let me know if you're having a similar issue! If so, this is a known bug, and our eng. team is working on a solution.
