Recording converting -now disappeared- please help
I recorded my class last night to cloud. I finished it as normal and closed the laptop off. This morning i've open the laptop to find the meeting and it wasn't there. There was a zoom pop up window saying "Meeting not converted" 64% converted - so I allowed it to finish which it did but it isn't anywhere to be found. Please can someone help me, any ideas as to what has happened?
Why was it converting and how can i find the file. Thank you @members
Thanks Katie
Check here.... Windows: C:\Users\[Username]\Documents\Zoom
This should be your documents folder, check for a folder named, zoom
Hi
It seems you actually recorded to your device and not cloud because zoom meetings recorded to the cloud do not need to convert, zoom processes it and sends you and email notification that your recording is ready.
Check your device for the recording since you allowed it to complete.
I hope this helps
ktingersAuthor
Thanks this would make sense but why doesn't it appear in my "local" folder then? Shouldn't it be there? Any idea where it would save to on my PC? Trying to search. Thanks
This has now happened to me twice in 2 months.  I am not happy.  I record dance classes.
