Recording | Community
Recording
  • October 6, 2021
  • 5 replies
  • 20 views
Please help. I was on a zoom. I started recording but stop that recording and started a new one during the meeting. When we ended the meet, it only saved the first recording not the second one. Is there a way for me to locate the second recording.
    Did you check the recording you have to make sure your recorded portions were not all included in that one recording?
    as though you had paused and restarted the recording?
    Yes, I did. It was just the first video recording. I don't actually need that one. It was a practice. I am needing the second recording I made.
    Okay, wait. I found it. You are right.  After the first video played through then the other one loads up and starts. Is there a way to erase the first half.
