Recorded audio and video not in sync | Community
  • August 6, 2022
  • 114 views
I have recorded a video through the zoom desktop client. Recorded it to the local disk, not uploaded to the cloud not down loaded from the clouds. The video is from a Canon Vixia, connected through a Can Link 4K. The audio is coming through a Roland Cakewalk UA 25 EX,  USB Audio Capture, vocals into that from an Audio Technics  microphone, guitar plugged straight in from the internal pickup. When I play it back on my own computer, that recorded it originally, the audio and video and out of sync, not hugely, but noticeably. Does anyone have any suggestions? I have not found this problem discussed anywhere.
Thanks,
Dougal
    Not sure if you're still having trouble with this. I've had the same problem using the Cam Link 4K on Zoom. For recordings, try recording to a local drive. That worked for me with recording a Zoom "Clip," the new Beta feature as of August 2023. I haven't tried it with a meeting recording, but my hunch is that it would work, since Recordings settings seem to control Clips. You could also use OBS and NDI to introduce a delay in the audio. That works, but it's a lot of setup. You can find instructions for how to introduce audio offsets with OBS and NDI online. A good video card helps, but doesn't completely eliminate the issue.
