Oct 10, 2024 5:00 PM UTC
Record presentation and speaker side-by-side
I am trying to record a presentation with a speaker shown in a thumbnail, same as what's shown in this how to article for 'Shared content with active speaker'.
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0062314
I used to be able to do it but lost the control setup I guess.  Instead, I get a thumbnail on top of the presentation, but I'd like the speaker to be off to the side.
In my account under Settings >> Recordings, I have all the recommended settings from the article checked.  There are some settings in the Share Screen panel when you open it, but I can't find a description of what they do.  Perhaps one of them adjusts what's seen for the recording?
jdott16
Oct 14, 2024 6:06 PM UTC
Hello   @pdxNordic
If you scroll down that article a little further, you can make sure your recording has "Share with participants video next to shared content:" enabled which should allow you to have the thumbnail off to the side. Please see the note in the article here: https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0062314#:~:text=previous%20video%20layout.-,Note%3A%20Your%20recording%20layout%20will%20change,-based%20on%20whether
I hope this helps and please make sure to mark the solution as accepted if this information is what you needed.
Thank you,
Jake
