tom cary
Contributor I
Contributor I
Mar 11, 2026 2:24 AM UTC
Random Zoom Disconnections – Need Help!
Hey everyone, does anyone know a good way to fix random disconnections during meetings? My Zoom keeps dropping and it’s super annoying
Contributor I
Mar 11, 2026 2:38 AM UTC
  1. Check your internet connection – use a wired connection if possible or move closer to your Wi-Fi router.
  2. Update Zoom – make sure you’re on the latest version.
  3. Close background apps – apps using bandwidth (like streaming or cloud backups) can cause drops.
  4. Adjust Zoom settings – try disabling HD video or virtual backgrounds to reduce load.
  5. Reinstall Zoom – sometimes a fresh install fixes persistent issues.
Hope this helps!
