quality of sound
How to improve the quality of the transmit sound for musique ?
    Hi @DOM1, do the following to see if this helps! You can find these settings in your Zoom desktop client settings > Audio
    • Uncheck Automatically adjust microphone volume, so you can adjust your volume to your desired liking.
    • Set Suppress background noise to low to optimize for music, or if it helps to depend on your surroundings try Auto.
    • Check the box for Show in-meeting option to “Enable original sound” from microphone. By default, Zoom processes audio to make speech easier to hear, but that can distort the music. Enabling original sound shuts off that processing.
    • Dependent on your CPU and Internet connection, you can try enabling High fidelity music mode.
    I hope this helps you out!  😀
