Mar 23, 2026 8:16 PM UTC
Quality of audio recording is poor
Hi, new to this group, hope someone can help. I record a weekly meditation via Zoom (latest version), and usually incorporate music as part of that. Having some problems though - the audience can hear me OK, but a) when i played from the music from my laptop, no sound went to the audience, and b) when I played it from my phone, the music was very muffled.
I have made sure that 'original sound for musicians' is enabled, and I've also gone back to 'noise removal (default)' and selected 'low'.
That last option worked ok on my old HP surface pro device . Neither of these options is giving me good sound quality on my new device.
ExpertswhoJohn
Mar 24, 2026 6:32 AM UTC
hi ​@Peter Lumsden
You machine is ignoring the music as background noise.
You are right to check for
But many laptops now have a similar setting in Windows 11.
So loow at your windows sound settings.
