PWA and audio | Community
PWA and audio
  • March 3, 2023
  • 0 replies
  • 46 views
I have used the PWA with my chromebook, and like parts of the app enough to use it on Chrome on my Mac too. But there is a problem with screen sharing.
Every time you screen share you must remember to turn off the audio of the tab you're using, otherwise you can't explain what you're sharing.  Couldn't there be a way to make OFF the default setting?
