Mar 31, 2026 8:42 PM UTC
Problems with recording
We are trying to record both voices and piano playing during a meeting. We can only seem to record the voice??? We have tried some suggestions found online.  Is there a simple way to do this???
Thanks
Patti McCallion
    ExpertswhoJohn
    Apr 1, 2026 6:40 AM UTC
    hi ​@DomCon
    OK, I have not tried this but I think this will work the best
    1. Make sure you have original sournd for musicians active for everyone. This will stop them being seen as background noise.
    2. I also suggest that in advanced recording options you try record seprate audio. THis way zoom will make a separate audio recodrding of each person and not prioritise one over another.
    All the best
    John Drinkwater
    Zoom Developer Champion
    https://lordzoom.com/go/hub
    ExpertswhoJohn
    hi ​@DomCon
    All the best
    John Drinkwater
    DomConAuthor
    Apr 1, 2026 3:54 PM UTC
    Thanks so much! We will give it a try.
