Aug 16, 2021 7:22 PM UTC
Problems with freezing screen and getting help from support team
Since the recent upgrades, my screen has been freezing in meetings with clients, and the only way I unfreeze them is to minimize the screen and then maximize it again, which I have to do every few seconds. I have been on the online chat support 3 times with 3 different support staff, all who have advised me to uninstall current app and then install new version. This has not worked to date. I have cleared my browser's cache. I have no problem with my wifi bandwidth. I need help and cannot get it.
    Aug 16, 2021 8:22 PM UTC
    juan garcia deaf
    Aug 16, 2021 9:47 PM UTC
    I am having the same problem . The view of the participant freezes on my computer.  The audio remains ok  but there is no video movement of the participant
    Aug 17, 2021 4:01 PM UTC
    That's exactly what I had. I finally got some help after a week of asking and was sent a link to a couple of different versions of zoom. The first one worked, I hope, fingers crossed!!! Here is copy/paste of their suggestion:
    Here is the link to download the previous version of the Zoom application:
     32-bit: https://zoom.us/client/5.7.4.804/ZoomInstaller.exe
     64-bit: https://zoom.us/client/5.7.4.804/ZoomInstaller.exe?archType=x64
    Kindly install the version that is compatible with your device, if your device is  64-bi, please download the previous version of 64-bit.
    Aug 19, 2021 3:51 PM UTC
    I've been having the same problem as this so thanks for the links.
    Nafi
    Community Champion | Partner
    Aug 17, 2021 12:33 AM UTC
    Hi
    What devices do you use and what is the version, based on your information maybe you need to make sure your OS is within stable version and make sure your hardware driver also stable.
    Seems like checking your cpu utilization when you are on the zoom meeting will give you visibility for your resources.
    Hope it helps! please like and mark this as solution so whenever someone has the same question this content will help.
