Problems hearing one participant | Community
  • January 29, 2025
  • 118 views
Hello, during an online class I could hardly hear one participant. The voice was disappearing. I heard other participants very well and, oddly enough, the others could hear him, but not me. He had his contactless earphones. What should I/ he do next time so I could hear him?
Best answer by lancetlc
Hey @just_pasteque,
I'm sorry to hear that you're experiencing issues with hearing your participants before and after Zoom meetings. It's possible that a recent Zoom update might have changed some settings. Here are some steps you can try:
  1. Check Audio Settings: Verify that your audio settings in Zoom are configured correctly. Click on the gear icon (Settings) in the top-right corner of the Zoom desktop app or web client. Check the "Audio" tab to ensure the correct microphone and speaker are selected.
  2. Adjust Meeting Options: During a meeting, click on the arrow (^) next to the microphone icon to access the meeting options. Make sure the "Mute on Entry" option is not enabled. This will allow participants to join the meeting unmuted, and you should be able to hear them.
  3. Unmute Participants: If your participants are muted during the meeting, you can unmute them by clicking on the Participants button on the Zoom toolbar, finding their name in the participant list, and clicking on the "Unmute" button next to their name.
  4. Host Controls: Double-check the host controls to ensure there are no specific settings restricting participant audio before or after the meeting. Go to the Zoom web portal (https://zoom.us) and sign in to your account. Navigate to "Settings" > "Meetings" > "In Meeting (Advanced)" and review the options related to participant audio.
  5. Update Zoom: Make sure you are using the latest version of the Zoom app. Outdated versions may have compatibility issues. You can download the latest version from the Zoom website (https://zoom.us/download).
  6. Test with Different Participants: To rule out participant-specific issues, try conducting a test meeting with different participants to see if the problem persists.
  7. Restart Device and Router: Sometimes, a simple restart of your computer or device, as well as your internet router, can resolve temporary glitches affecting audio.
lancetlcAnswer
Hey @just_pasteque,
Hi @just_pasteque! I wanted to let you know that I’ve marked @just_pasteque's response as the accepted solution, as I believe it answers your question. If you have any more questions or need further clarification, feel free to ask.
