Apr 17, 2025 12:09 PM UTC
Problem with Zoom finding my external camera
hello - i have a problem, zoom will not find my external webcam (using a sony a7iii). it only allows me to select the integrated laptop webcam. this problem only occurs on my laptop, i can use my webcam on my desktop no problem. The laptop is a dell latitude and is running up to date windows 11 and the version of zoom is the latest.
I have tried adding camera permissions to zoom in windows - but the only option there is to add permission for the laptop camera.
The cable I am using is good and works fine on my desktop. I have tried deleting and re installing zoom and checking for latest firmware for camera and zoom. Any ideas?
bstrelko
Apr 17, 2025 5:07 PM UTC
Does the laptop have webcam drivers for the A7III installed? Are you able to use the camera on this same laptop for other applications?
