Problem with Zoom Android SDK integration | Community
  • May 22, 2023
  • 95 views
My application uses TensorFlowLite library. And I want to add a Zoom Android SDK, but i got a problem of duplicating files:
2 files found with path 'lib/arm64-v8a/libtensorflowlite_gpu_jni.so' from inputs:
- /zoomtest/dependencies/mobilertc/build/.transforms/351c5d94fe06d53d53e7f1b1cc2fa5e2/transformed/mobilertc/jni/arm64-v8a/libtensorflowlite_gpu_jni.so
- /.gradle/caches/transforms-3/2b2676791d20bed97ecf782ed5d9c783/transformed/tensorflow-lite-gpu-2.5.0/jni/arm64-v8a/libtensorflowlite_gpu_jni.so
Also I tried to add `pickFirst` to my build.gradle file:
packagingOptions {
pickFirst 'lib/arm64-v8a/libtensorflowlite_jni.so'
pickFirst 'lib/arm64-v8a/libtensorflowlite_gpu_jni.so'
and it doesn't help me, because I got  exception during runtime process, that native method wasn't found.
Any ideas, how to solve it? Which version of TensorFlowLite do you use in your SDK? Is it possible to add appropriate version of TensorFlowLite to project and add `pickFirst` to build.gradle file and after this build and run project without errors?
    May 22, 2023
    Welcome to the Zoom Community, @evgeniyk7
    This is a question more appropriate for the Developers Forum at https://developers.zoom.us/
