Mar 25, 2025 9:04 PM UTC
Problem with automatic recording of scheduled meetings in Cal.com and Zoom
Why don't the meetings that are scheduled for me by Cal.com automatically record in Zoom, if I have it set to record at startup?
Vinnie
Mar 25, 2025 11:16 PM UTC
Hello @GianmarcoRusher
I am not familiar with the cal.com service as a scheduler for Zoom, but I what I can say is "Automatic Meeting Recording" is a feature that depend of your Zoom Account settings.
I would suggest to look and check the following:
  • I know Outlook calendar and others sync the Zoom Meetings default settings from the Zoom Portal, and allow you to override some of those on a per-meeting basis. Check the cal.com doesn't the same, or maybe has it own Meeting Default Template settings overriding Zoom Default settings.
  • Check the Zoom Portal Default settings for Automatic Recording (and others in there) by to going to your Zoom Personal Portal:  "PERSONAL > Settings > Recordings" scroll until you find "Automatic Recordings" and verify it is enabled. I don't know your case but in some Business Environments, that setting is forbidden to be enabled and locked by Admin. If that is your case, you need to talk to your Zoom Admin and make your case of needed that enabled.
  • After you have Scheduled a meeting with cal.com, go to your Zoom portal to verify the meeting it showing in there as well: "PERSONAL > Meetings > UPcming"
I hope this helps, and if so, please mark this as (Accept as Solution)
Attached is a picture of how it looks like when the option is Disabled and Disallowed by the Zoom Administrator (my personal case).
