problem with audio when I share the screen | Community
  • June 29, 2025
  • 6 replies
  • 1007 views
when I share the screen and activate the audio sharing function for the computer, the audio automatically stops playing. The youtube videos for example are still playing but without sound. i need urgent help
Hello @marinaplana,
Kindly try updating your Zoom app and audio drivers to the latest version.
Thanks for your message. I updated to the latest version and gave permissions to the app but it still does not work. I connect from a macbook air. Could you tell me what other settings to take into account?
I'm sorry for the delayed response. You may try these troubleshooting steps:
1. Use the correct screen sharing method
Click Share Screen
Select the window or screen you want to share
Make sure to check the box "Share sound" at the bottom left before clicking Share
Avoid sharing a browser tab with sound unless you select "Chrome Tab" share if available (Zoom can be picky with tab audio sometimes)
2. Check your audio devices and settings
In Zoom, go to Settings > Audio
Under Speaker, pick your default audio device (e.g., your headphones or speakers)
Try toggling “Automatically adjust microphone volume” off/on to see if it helps
Also, test your speaker using the Test Speaker button
3. Disable “Allow applications to take exclusive control” on your sound device (Windows)
This often solves weird audio-cut problems:
Right-click the speaker icon in the system tray → Sounds
Go to the Playback tab → select your active device → Properties
Go to the Advanced tab → uncheck Allow applications to take exclusive control of this device
Click OK and restart Zoom
4. Try using "Share computer sound" with "Optimize for video clip."
When sharing screen, in the lower left, besides Share Sound, also check Optimize for video clip
This setting helps smooth playback of videos and audio.
5. If you’re using Bluetooth headphones or external devices
Sometimes Bluetooth devices have issues with audio sharing:
Try switching to wired headphones or built-in speakers and test again
Alternatively, try disconnecting and reconnecting the audio device
 I am trying to follow the steps listed above however there is no "share sound" link at the bottom.  Where do I find this please?
