Oct 22, 2025 12:17 AM UTC
Problem when using original sound with bluetooth
6.6.0.33360
Galaxy S23+ SM-S916U
OneUI 8
Android version 16
When I join a meeting, I am able to use "Original Sound for Musicians" but if I use it with a bluetooth device (Logitech Zone Wireless 2) then I sound like a chipmunk to everyone in the meeting. If I turn off bluetooth or Original Sound, then I sound fine.
One of my colleagues who also uses an Android has the same issue.
Oct 25, 2025 4:20 AM UTC
search Google for "why does Zoom "Original Sound for Musicians" with a bluetooth device (Logitech Zone Wireless 2) sound like a chipmunk to everyone in the meeting" for all the details.
Oct 30, 2025 3:35 AM UTC
Hello gmaximus, our investigation has revealed that the issue is with Samsung Android 14 and above, causing problems with microphone data acquisition. If using a Bluetooth device, please do not use "Original Sound for Musicians". Thank you for your feedback.
gmaximusAuthor
Nov 6, 2025 6:34 PM UTC
So, the answer is "don't use bluetooth or don't use Original Sound for Musicians."
I knew that already.
If I didn't need to do both, I wouldn't have asked the question.
Nov 24, 2025 7:14 AM UTC
@gmaximusWe are attempting to fix this issue in the upcoming 6.7.0 release using a special method that bypasses Samsung's system problem. Thank you very much for your feedback.
