Problem since 2 week while using zoom with 4G
since 2 week while using zoom meeting to record my on line courses I meet several problems :
1/ my micro makes strange noises
2/ my connection is instable, and spot while recording.
si I am confused because before that it was ok
but since the two last weeks (approximatively) my reseau swich off as soon as I start using zoom.
I check the volume of data that I can use per month and and don’t use a lot of date so I don’t think it is the problem.
dors any of you had the same issue??
thank for tour helps
