Aug 29, 2022 1:02 PM UTC
Problem opening zoom application on Mac desktop
I have been using Zoom for some time and use it for regularly for meetings. Until today, I had no trouble opening the app from my applications folder. When it wouldn't open, I downloaded the software again but a message popped up to say that I can't open the app because PowerPC applications are no longer supported... I am running an iMac with OS 10.11.6. Does anyone have a solution?
    Aug 29, 2022 2:24 PM UTC
    Hello - I have Windows & I have been trying to access Zoom on my laptop & I cannot. Not only me, but other people I know, they cannot attend a Zoom meeting via laptop. However, I can access it with mobile devices, which I don't want to necessarily do.
    Aug 29, 2022 7:59 PM UTC
    I am having same problem on my iMac.  Didn't have problems in the past.  I can still use it on my laptop, but since I am teaching, the desktop is much nicer for me to use.
    Aug 30, 2022 6:08 AM UTC
    If your Mac can still boot to the older OS X system, then that's one choice: Keep your games or other apps with the older OS X system, maybe on an external drive. Boot to that older system when you want to play (or work 😄 ) with the older apps.
    It's also possible to run an older OS X system in a virtual machine (using Parallels or VMWare, etc). I don't know how to set that up, but there's others on this site that can give some info about do ing that.
    Jilly50Author
    Sep 1, 2022 1:00 PM UTC
    Thanks for the suggestion re: using an external drive for an older system. I don't know what happened but after re-loading the zoom software it started to work properly again, just in time for a meeting!
    I'm not a very tech-oriented, so very relieved that it's up and running again.
    Sep 9, 2022 8:47 PM UTC
    Having the same problem on my macbook 12.5.1
    Any one discovered the solution yet?
    I tried the chat for help, by email... does any one can resolve this?
    This is affecting my work...
