May 24, 2024 4:41 AM UTC
Problem of being invited to past mtg
After setting the MTG from the zoom schedule, I will send an attendance request to both A and B from Outlook at the same time.
A receives the correct meeting link, but for some reason B receives the old meeting link.
Both of them use Outlook on Android. They received an invitation email in outlook, and when B opens the attached ics file, it is a past mtg invitation.
Humashankar
May 26, 2024 12:21 AM UTC
Hi @Hiroyuki_49
Try the following steps to resolve the issue:
1. Remove the meeting invitation from your calendar.
2. Refresh your Outlook calendar to ensure it's up-to-date.
3. Open the new ICS file you received and re-add the meeting invitation to your calendar.
This should update the meeting details and resolve any issues
Hope this helps - Happy to help further!!
Thank you very much and have a great one!
Warm regards
Humashankar
Hi @Hiroyuki_49
Warm regards
