PRO plan
i was created meeting already but now if i will upgrade to pro plan link will be change or not ?
    Ohkawa
    Hi, @MssKendriy
    Usually, the link will not change.
    However, there is a possibility that https://xxx.zoom.us/j/ZZZ will be changed to https://yyy.zoom.us/j/ZZZ.
    In this case, you will be able to join the meeting using the link with yyyy. removed "https://zoom.us/j/ZZZ"
