Feb 3, 2022 4:51 PM UTC
Power Point does not advance in Share Screen mode
When I share screen to present a pptx file and change slides, the slides advance on my screen, but not for the viewers.
I have tried to reinstall Zoom, but to no avail. Help!
    Mar 22, 2022 11:44 AM UTC
     I have the same problem...any comments to solve it? thx
    jmellinoAuthor
    Mar 22, 2022 1:59 PM UTC
    Nobody has had any suggestion until now... 😞
    Jul 5, 2022 8:57 PM UTC
    this is also my issue.  Did you resolved this?
    May 29, 2023 6:41 AM UTC
    Same problem here for one of our users. Has there been any resolution for this?
    May 29, 2023 6:49 AM UTC
    Greetings, all: @jmellino, @ATur, @mige82666, and @nando:
    I think one reason you might not have any answers is that screen sharing steps are pretty standard, and if you follow them, it's extremely rare for something not to work right.
    Here's the definitive Zoom Support article on Screen Sharing:
    https://support.zoom.us/hc/en-us/articles/201362153-Sharing-your-screen-or-desktop-on-Zoom
    And here's a User Guide I wrote for presenters in Meetings and Webinars that I facilitate:
    https://meetingsandwebinars.com/userguides/how-to-screen-share/
    One of these hopefully helps you get your Screen Share working.
    jmellinoAuthor
    May 29, 2023 7:26 AM UTC
    Thank you for this, much appreciated that you react even to tis old post. But sharing screen is simple and not a problem per se. The problem is that when I share my screen and showing a ppt in full screen, the ppt does not advance for the other viewers (it does on my screen). I have done this at big meetings with IT support, and the techs have not been able to solve the problem.  I have found a "sort of way" around it, by using "reader's view" (translated into English, does not know the English term) on the ppt, but I lose several functions...
    May 29, 2023 8:07 AM UTC
    Hi, @jmellino.  Yeah, sometimes when I have time I go back and look at old posts that don't have a solution -- and for which I have some knowledge.
    The only way I know of that your situation comes up is if the Screen Share is somehow Paused.  This causes the current snapshot of the screen share to be frozen for all other attendees.  Your floating screen share bar will look like this:
    The button to the right of Share Screen says Resume Share, and the part of the bar that is normally green is now orange.  If this occurs, click the Resume Share button and your computer should resume sharing, like this:
    The button to the right of Share Screen says New Share, and the left two-thirds of the lower bar is now back to green, as normal during screen sharing.
    Also, please make sure you have updated to the latest Zoom desktop app.  Small fixes are made in almost every release -- and sometimes something is fixed that affects a rare occurrence like you're experiencing.
    If you continue to have this issue, please ask your IT department to work with your Zoom Admin to log a Support Ticket with as much detail as possible.
    I'll attempt to send you a PM in the next few days.
    Feb 20, 2025 10:11 PM UTC
    I had the same problem last night during a hybrid presentation. I went back to the window which shows all the open documents on my computer and found one called "screen 2". I clicked on that and the slides started advancing again for the zoomers. Pure luck!
