PMI and Auto generated meetings in use at same time | Community
  • January 9, 2025
  • 52 views
If I have PMI meetings with my link set up as recurring for someone else to use and I plan a meeting at the same time with an auto generated link, can I use zoom this way? I have in the past but the past couple of months, If I do this when I go to 'join' the auto generated link I end up in the meeting using my PMI?
ArvinG
Hello @WendyTX – It sounds like you're trying to host 2 meetings simultaneously (1 w/ your PMI + 1 w/ the auto generated link), correct?
If so, then this is possible depending on the type of license you have:
  • Basic / Pro license – You can host only one meeting at a time.
  • Business, Education, or Enterprise – Allowed to host up to two concurrent meetings.
You can also refer to this Support Guide.
