Jan 14, 2023 12:55 AM UTC
Original Sound not detecting instrument audio 5.13.3
Hi Zoom Community,
I've been using Zoom for clarinet lessons with my old laptop for almost 2 years, never had any problem with original sound. Teacher has always been able to hear me playing.
However, recently bought a new laptop and installed 5.13.3 then problem occurred. With screenshot of setting attached, Zoom is not able to record instrument audio as well as vocal audio completely. It either records part of it or not at all, however Zoom can record a full conversation without any issues.
Have tried changing the selections in Advanced setting, but neither works.
Can someone please help me out? Thank you.
    Jan 14, 2023 1:52 AM UTC
    hi 2023,
    on the top left of your zoom meeting screen, have you toggled original sounds for musicians from 'Off' to 'On'?
    Hi2023Author
    Jan 14, 2023 4:16 AM UTC
    Hi Eliot,
    Yes I have enabled Original Sound for Musicians, but can't hear me singing or playing, only talking can be heard.
    ZoomTestKitchen
    Specialist
    Specialist
    Jan 14, 2023 5:17 AM UTC
    All  your Zoom settings look correct, which makes me think that your new laptop may have some audio processing software preloaded on it that is running behind the scenes. I would recommend taking a look at Windows Task Manager -> Startup Tab to see if any of the apps/services that auto-start jump-out as the culprit. If you think you find it, then right-click and disable it.
    I have a very long list of these apps, and have almost all of them disabled. Most just are not essential.
    If you find this information helpful, please click on "Accept as Solution".
    If you have further questions, please reply, we're happy to help.
    Jan 14, 2023 2:53 PM UTC
    Hi Jeff, I am hoping you can help me.  When  as a guest playing guitar the others in the room hear muffled sounds to not hear me playing guitar at all. I am not tech savvy but with help I can follow instructions. I have an HP Windows 11 with intel i5, 8 gb ram, 256 ssd. Initially I used the built in microphone but hearing my guitar was inconsistent and very poor. Then a friend purchased a usb microphone which initially worked well with my voice and guitar I was told. But, as of the past few weeks the guitar playing has been muffled sounds to cutting out to none. The voice is fine.
    Your suggestions will be much appreciated.
    Thank you.
    Jan 15, 2023 6:03 PM UTC
    I think it’s an upgrade issue. Log a ticket with zoom they might look into it quicker it’s causing me serious issue for my work.
    Jan 14, 2023 3:42 PM UTC
    Hi I had the same problem with my new PC and playing the violin for music lessons on zoom. (It used to work OK on my old PC.)   I followed all the instructions about audio for musicans and made sure that Original sound for musican was set to On but it still didn't pick up my violin.  I then looked under the advanced tab and changed the "Signal processing By Windows audio device drivers" from auto to Off.  Zoom now picks up my violin correctly.
    I hope that this works for you.
    Jan 15, 2023 6:04 PM UTC
    I think it’s an upgrade issue. Log a ticket with zoom.
    Jan 31, 2023 7:49 PM UTC
    Based on their most recent update (see latest article related to original sound), it looks like users will need a paid account to access the original sound feature. It's not extremely clear and there are thousands of music teachers/students who are frantically searching for other options/alternatives to Zoom this month.
    If this is not the case, then Zoom Support needs to clarify the update.
    Apr 8, 2023 4:03 AM UTC
    Finally the right answer -- they are maybe cash strapped and want to kick all of the free loaders (our students) off of the platform.  If this is a substantiated case, we teachers should all boycott their system all at once and make them more cash strapped.  I'm now on the hunt for a Zoom replacement
    Oct 3, 2024 2:56 PM UTC
    I found a couple of alternatives, but some make the users (student) go through some gyrations to use it -- meaning I have to consider writing a user guide/tutorial how I want my students to use this system.  Or overly simplified but lacking in features.  Somewhere in the middle would be nice -- just like where Zoom used to be and was simple, powerful, and easy to use by everyone.  Now it's corporate junkware that only cares about getting corporate users to compete with the big boys (WebEx, Teams, etc.).  BTW, I've started looking a JackTrip and JackTrip Studio, if I can figure out how to make it super simple for my virtual students.
    May 11, 2024 6:26 PM UTC
    I am trying to enable orginal sound for musicians but when I follow these instructions
    How to enable and configure original sound for musicians
    https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0059985#h_01GZ2K7TDMTK8YCKCTQ4JJ2NWB
    but when I get to step three there is no "audio" tab so I can't enable it.  I would really like to get this done ASAP
    May 11, 2024 7:32 PM UTC
    Op[en zoom (not a zoom session).  Click on the button on the top right it has your initials oon it.
    You will get a drop down list with settings as an option
    Click on settings and audio is one of the options on the settings list
    Click on audio and then enable the Live performance option
    May 11, 2024 7:59 PM UTC
    The pdf shows the zoom screens you use
