Jul 31, 2024 1:21 AM UTC
Original Sound for Musicians ON but still can't hear flute sound!
I teach flute lessons online.
Last night and today, even though my students had selected the "ORIGINAL SOUND FOR MUSICIANS" ON, I could not hear their flute sounds.
Is anyone else experiencing this issue today? Could it be server or update issues?
Jul 31, 2024 9:07 AM UTC
Yes i am having the same problem. Even with "ORIGINAL SOUND FOR MUSICIANS" turned on, I can’t hear my students' flute sounds. It might be a glitch with Zoom or maybe something with the servers or a recent update. Hopefully, it gets fixed soon
Aug 28, 2024 8:19 PM UTC
I am having the same problem.  I will have to cancel the class because the instrument sounds are not coming through even with Original Sound for Musicians on and all boxes empty.
Aug 28, 2024 9:50 PM UTC
I discovered that iPhone has a system noise cancellation that needs to be turned off as well!! Write me on FB or IG and I'll send you the demo instructional video I made if you want.
Aug 28, 2024 8:43 PM UTC
Hello there,
I'm sorry for the inconvenience you are experiencing. Just to set your expectations, the original sound for musicians need to be turned on during every meeting. If you have turned on the setting before a meeting it will not take effect.
Please let me know if you need further assistance.
Oct 9, 2024 9:54 PM UTC
Thank you for your response. Your answer does not fully address the above concern.
I know that not only does the Original Sound have to be enabled in the settings, but also engaged during the meeting. I tell all of my students there are TWO STEPS to turning on the Original Sound!
I have also discovered through this thread that that some devices including iPhones have a system default echo cancellation... turn it off in the phone's system settings.
Some laptops too. It may be through an app called RealTek.
However, sometimes, it seems I still have difficulty hearing students.  Fortunately most of them have more than one device and through following these steps we can usually find one that works.  If you have any further details I would appreciate it.
Oct 7, 2024 9:13 PM UTC
Your answer does not address the above concerns. All posts said that they had original sound for musician turned on.  Yet still, the flute sound does not come through. I am experiencing the same issue today 10/7/2024. Please advise.
Oct 8, 2024 12:20 AM UTC
I found out that turning "Original Sound" on in the settings only gives you a toggle button at the top left of the screen (Mac). You have to toggle that button to 'ON' to actually turn it on. This finally worked for me.
Oct 9, 2024 9:51 PM UTC
Yes, thank you but I already know about this.  I tell all of my students there are TWO STEPS to turning on the Original Sound!
I have discovered that that some devices including iPhones have a system default echo cancellation that has to be turned off in the phone's system settings. Some laptops too, and for some of them it's through an app called RealTek.
Oct 8, 2024 12:41 AM UTC
Yes, I am aware of this, as are my students. We always click the Original Sound for Musicians toggle and still cannot hear flute sound. They can hear MY flute (I use an auxiliary mic, not sure if that matters in this context) and I can hear students who play other instruments (ukulele, guitar). Just not my flute students flute. This is a problem specific to flute. Others have described it above. It is also a new problem, as of this week, for me.
Oct 15, 2024 8:41 PM UTC
Kindly try configuring for live performance mode.
Enable live performance audio during a meeting
  1. Sign in to the Zoom desktop client.
  2. Start or join a meeting.
  3. Connect to meeting audio with the Computer Audio option.
    In the top-left corner of the meeting window, the current status of the live performance audio feature is indicated.
  4. Click the Live performance audio icon to toggle this on or off.
    A notification will appear, indicating if the feature is currently enabled or not.
Notes:
  • All participants in the meeting must have this audio profile enabled during the live meeting; otherwise, the improved latency is not achievable.
  • At this time, cloud recordings do not support Live performance audio. The cloud recording will not capture anything when Live performance audio is enabled in a meeting.
Nov 3, 2025 6:42 AM UTC
Thaks for your concern, Mark. My original sound for musicians always toggled fine during meetings until the second-to-last update, about 3-4 weeks ago, I think. At that time, it was stuck in the "on" position.
It will go off in sound settings if I press echo cancellation, but not on the screen. When I choose original sound in sound settings, I have high fidelity and echo cancellation checked. I checked Mac laptop settings and do not have either default echo cancellation or RealTek. Should I uninstall and re-install Zoom?
Nov 6, 2025 2:09 PM UTC
Mark, it look like you are on line now. I would love some help with my "Stuck on off" Original sound! (See above from 11/2/25.( I have a Zoom concert happening this Sunday and I need to turn on Original Sound before then! I have tried relaunching Zoom workplace but the problem described above still occurs. THANK YOU for any suggestions! Sherry
Jan 6, 2025 12:13 AM UTC
Yes, I can not hear my friend play her piano; I can hear her voice only, and vise versa. We changed our Audio settings and then she could hear me (sort of) she would hear every other key I played. I think the microphone was pausing in between my key and note strokes.????
