Oct 29, 2026 1:01 PM UTC
Original sound for musicians not working on laptops and tablets - both Mac and Windows/android
Just this last week, Original Sound for Musicians has not worked for my music students. They use a mixture of laptops and tablets, some Mac, some Window/Android. Their instruments cannot be heard at all. In contrast, they can hear my guitar. I use a desktop PC and an external mic/webcam.  Each student has followed all the suggested adjustments to their microphone and security settings, and all of them had no issues at all until just recently. This has rendered Zoom to be unusable for online lessons at the present time. It is as if the Original Sound settings have been overridden by the inbuilt mics that everyone is using.  However, the problems was not removed for the student who set up an external USB mic to her Lenovo laptop (The very same mic worked for me when tested with my PC).  As this is affecting Mac and Windows, is it some kind of update on Zoom? It is mystifying.
Please Zoom can you do something about the settings for Original Sound?
    Oct 29, 2026 2:01 PM UTC
    Most current operating systems have their own noise reduction that can interfere with music.
    If Zoom is still muting your instruments, your IOS device  might be enforcing its own system-level noise cancellation. Zooms settings and the operating systems noise cancelling need to be set up to work together.
    Use Voice Isolation, Wide Spectrum, or Automatic Mic Mode on your iPhone and iPad
    1. While actively inside the Zoom meeting, swipe down from the top right corner of your screen to open the iOS Control Centre.
    2. Tap the Mic Mode button (usually in the top right).
    3. Make sure it is set to Standard (or Wide Spectrum if available). Do not select Voice Isolation, as this will forcefully block out your music.
    Use Mic Modes on your Mac
    Go to an app that supports Mic Modes, such as FaceTime or Zoom
    Click Video in the menu bar, then click Mic Mode.
    Do any of the following (options vary by app):
    • To filter out background sounds, select Voice Isolation.
    • To include the sounds around you, select Wide Spectrum.
    • To revert to the standard mic mode, select Standard.
    I’m not an android person, maybe someone else will chime in?
    Regards
    Oct 29, 2026 3:16 PM UTC
    Thank you very much for this helpful information about the iOS Control Centre, I will ask my Mac-using students to try this.
    I’ve received some information one of my students found about changes in the latest version of Zoom, I don;t whether this is relevant, and whether anyone has any comments on this: Zoom version 7.2.1 includes technical breaking changes to core audio interfaces and raw audio send buffer constraints in the SDK/app framework (such as removing deprecated pre-7.0.0 audio APIs and updating send buffer size limits), rather than a specific new feature designed to block instruments.
    Oct 30, 2026 5:21 AM UTC
    Hello Kevin,
    Thank you for the detailed description, and sorry for the trouble this has caused your lessons. To help us investigate, could you please provide the following:
    1.Meeting ID and meeting time (with time zone) of one or more sessions where the problem happened, so we can investigate the problem.
    2.The Echo cancellation setting from before, when everything worked: In Settings > Audio > Microphone modes > Original sound for musicians, was Echo cancellation checked or unchecked in the earlier lessons? For reference, see the attached screenshots:
    Screenshot 1: Original sound for musicians enabled, with Echo cancellation checked (on).
    Screenshot 2: Original sound for musicians enabled, with Echo cancellation unchecked (off).
    3.The Echo cancellation setting this time: What was it set to before the problematic meeting started? During the meeting, did the students see a pop-up notification saying Echo cancellation had been turned on because echo was detected?
    4.If it was turned on automatically, the student can uncheck Echo cancellation manually during the meeting so the setting matches Screenshot 2. Please let us know if that brings the instrument sound back.
    At this point, we can't yet confirm what is causing the issue. The information above will help us find out whether it is related to a feature introduced in Zoom version 7.2.0. When Original Sound for Musicians is enabled with Echo cancellation turned off, Zoom will automatically turn Echo cancellation back on if it actually detects echo in the meeting. A pop-up notification is shown when this happens. We added this protection because some users had turned the option off by mistake, which caused severe echo for everyone in the meeting. It is designed to protect the meeting's audio quality and keep the conversation free of echo. On laptops and tablets with built-in microphones and speakers, sound from the speakers can leak back into the microphone and trigger this detection. Once Echo cancellation is on, sustained instrument sounds may be suppressed sometimes or not , it is not sure.
    We'd also recommend that students use headphones during lessons. This stops the speaker sound from reaching the microphone, so echo is far less likely to be detected.
    Once we have the meeting details and the answers above, we'll review them and follow up with you. Thank you for your patience.
    Best regards
    Oct 30, 2026 5:25 AM UTC
    It would be helpful if you could share the Meeting ID and meeting time (with time zone) of one or more sessions where the problem first happened. Thanks.
    Oct 30, 2026 5:55 PM UTC
    I have been advised that I must not share any personal details but I can say that that every Zoom meeting I have had since 19 October when the problem first came to light has been beset by this problem, as I only use Zoom for music lessons, and in all meetings Original Sound for Musicians has been on and Echo cancellation was checked (on). No pop ups came up for anyone to advise that echo cancellation was being cancelled.All users are regular students who have had their devices set up for Original Sound for Musicians. Each of them has made efforts to check no only their Zoom settings but the microphone settings on their devices, but alas their efforts have been to no avail.
    If any help can be given, I would be very grateful. I have used Zoom for over 6½ years and have never suffered these issues before.  Many thanks.
    Oct 31, 2026 4:39 AM UTC
    Hello Kevin,
    Thank you for the additional information you provided.We are looking into the issue.
    In the meantime, here is a quick test that may help. In your next lesson, please ask your students to turn Echo cancellation off: go to Settings > Audio > Microphone modes > Original sound for musicians and uncheck Echo cancellation. Then check whether their instruments can be heard clearly.
    During the meeting, it's possible that Echo cancellation gets checked again automatically if Zoom detects echo. If that happens, please have the student uncheck it manually once more. Within the same meeting, Zoom will not turn it back on again after it has been turned off manually.
    This test serves two purposes. It quickly shows whether your lessons are affected by the new Zoom 7.2.0 feature, and it should let your lessons continue normally for now.  If Echo cancellation is confirmed to be off and the problem still happens, the cause is something else, and we will investigate further.
    To better understand your lessons, could you tell us a little more about how they usually go?
    1. How often do you and your students play at the same time, compared with taking turns?
    2. When you play at the same time, how often are you both playing the same piece of music, for example when playing along with each other?
    Thanks
    Best regards
    Oct 31, 2026 4:44 PM UTC
    Thank you for your help, Kate. I will test out the steps you have set out with Echo Cancellation at my next Zoom lesson, and I will report back as soon as possible.  Meanwhile, I can answer the questions you have posed about how we play in my lessons. I take turns with my students, as if we play together the timing is not in sync due to latency.  So I will demonstrate a piece or a section of music and then they play back to me and I listen and advise.  There are occasions when they may play along with me, but then I ask them to mute themselves so that they can hear me but I can’t hear them. This can be useful sometimes for them to work on their timing, but it’s only something I would do from time to time for a couple of minutes. So there is no echo issue then, as there is still only one instrument being transmitted over Zoom.
    Many thanks, and best wishes.
    Nov 1, 2026 3:55 PM UTC
    Thanks for sharing this so clearly, Kevin — I hope the test Kate suggested helps to narrow it down. One practical step that may help while you test is to change only one thing at a time and note the result for each student: device type, whether they are using a built-in microphone or an external USB microphone, and whether they are playing alone or together with you. Your example of the student whose problem cleared with an external USB microphone is a useful clue, as it points to how built-in microphones are being handled rather than to the lesson itself. If you keep that short note for the first few lessons, any pattern — for example, built-in microphones on one type of device — should become much clearer, and it will also give you a concise summary to share if the issue needs further follow-up. Best wishes with the next lessons.
    Nov 2, 2026 6:41 PM UTC
    I have now done the test that you suggested with some of my student, Kate. Dario, thank you for your post and for your encouragement.
    My students use various different devices, and they have all experienced the same problem - their instrument cannot be heard at all. They are all using their device’s built in microphone, which worked perfectly well until less than two week’s ago. I have asked three students to carry out the test with the echo cancellation setting.
    One student with a Lenovo laptop carried out all the steps. Starting with the usual settings of Original sound for Musicians selected, and with echo cancellation checked (on) - no sound coming through from their instrument. Turned off echo cancellation (unchecked it) - still no sound coming from their instrument (and my speech was echoing back to me). Turned echo cancellation back on - still no sound coming from their instrument (no voice echo experienced. Then unchecked echo cancellation - no sound coming through form their instrument still no sound coming from the instrument (my speech was echoing back to me again.) Checked it again - echo disappeared, still no sound from their instrument.
    I have asked two other students to carry out this test with me.  One of them has a Lenovo tablet, quite a new one. They went to their Zoom settings and has only two options - Original sound for musicians on, or off. There are no other options underneath these - no echo cancellation is listed.
    The other student has a Microsoft laptop, and they also have no echo cancellation option to choose. In fact in their Zoom audio settings they told me they do not even have the heading of ‘Original sound for musicians’ - their choices are listed as ‘Zoom background noise removal’ and ‘Browser built in noise suppression. Obviously they have ‘Zoom background noise removal’ selected. No sound is coming over from their instrument.  Two weeks ago, as with  the other students, everything was working just fine.
    None of my students use external microphones and I don’t feel I can ask them to purchase USB microphones, I am not convinced that this will make any difference. I carried out a test meeting at home with my wife who plugged an external microphone into her laptop and it made no difference.
    In relation to the broader questions that you posed, Kate, about playing at the same time as my students, and whether we play the same piece of music together, this is impossible to do properly, due to the delay time (latency) and it is accepted by music teachers using Zoom that we take turns, we play and demonstrate, the student plays and we listen carefully and advise/critique and coach and demonstrate again, etc.
    I hope that this information is helpful and informs a solution, whether adjustments could be made or recent changes could be rolled back.
    Thank you so much.
    Nov 2, 2026 7:23 PM UTC
    Thanks for running that test so carefully, Kevin — and for the detail about the Lenovo laptop. That result is actually very useful: echo cancellation on or off changed whether your speech echoed back, but the instrument stayed silent in every state, so echo cancellation on its own does not look like the cause there.
    The clue that stands out to me is that the built-in microphones worked perfectly until less than two weeks ago, across different devices. That points first to something that changed recently, rather than to each student's individual set-up. In order, I would check:
    1. A recent Zoom update resetting audio settings. In Settings > Audio, with Original Sound for Musicians on, re-check “Suppress background noise” and set it to Low for music, and turn off “Automatically adjust microphone volume”. Also make sure echo cancellation is not left on a High or aggressive setting where that option is available.
    2. The device's own microphone enhancements. On Windows, in the sound control panel or device sound settings, turn off any microphone enhancement, noise suppression or “voice clarity” effect, including any Lenovo audio effect — those can strip out an instrument even when Zoom is set correctly.
    3. App versus browser. The Microsoft laptop student's options — “Zoom background noise removal” and “Browser built-in noise suppression” — sound like the web client, which does not offer the same Original Sound controls as the desktop app. If they can, it is worth trying the same lesson in the Zoom desktop app.
    For the Lenovo laptop student, would you be able to check those first two points in a short test — noise suppression on Low, automatic volume off, and any Windows or Lenovo mic enhancement off — and let us know whether the instrument comes through then? The same check on the tablet student would help too, especially whether they are in the app or a browser. That should help separate a Zoom setting from a device microphone problem, and give Kate a much clearer pattern to work from.
    Nov 3, 2026 6:12 PM UTC
    Thanks, Kate — that first check feels especially useful here, Kevin. If the other students can hear the instrument while you cannot, that points much more towards your own playback or audio settings than towards every student’s microphone, which fits with all of them being affected at once. If you do try joining from another computer, it would also be worth noting whether the problem follows you or stays with the original machine, as that would help separate the two possibilities quite cleanly. I hope one of those tests gives a clearer direction for your next lesson.
    Nov 5, 2026 10:10 PM UTC
    I am really pleased to report that I have today held a music lesson on Zoom and I was able to hear the student’s guitar clearly. Thank you so much for your help, and especially to Kate and Dario for the detailed tests and steps that they suggested to identify the cause of the issue, and their responses to the finding that I reported.
    I will need to make sure that the problem has been resolved for all my lesson over the next week, but I am hopeful this is the case.
    I found that the problem lay with the settings on my PC, actually in the playback/audio settings - Speakers, rather than the settings for Microphones. I found that the audio enhancements for Realtek was set to ‘device default effects’ and when I turned this off, I could hear my student’s playing. I would add that I could hear his instrument more clearly that ever before.
    I will post again to confirm all is well once I have held all my weekly lessons.
    It’s looking promising, so full marks to the Zoom community!
    Many thanks
    Kevin
    Nov 9, 2026 6:57 PM UTC
    That's wonderful news, Kevin — I'm so glad to hear it worked, and even better that your student's guitar sounded clearer than ever. It really was a great catch, finding that Realtek 'device default effects' setting in your PC's Speakers/playback settings, rather than in the microphone settings. Do let us know how your other lessons go this week — I hope they all go just as smoothly.
    New Member
    Nov 6, 2026 11:29 AM UTC
    Glad the iPhone test came out clear. For the students who still sound bad, wired headphones make a big difference with Original Sound, because echo cancellation can then be turned off without their speakers feeding back into the mic. For the Windows tablets that don't show the "Use echo cancellation" option, it may be worth having those students sign in to their own Zoom account on the web and check the audio settings there. Some of the in-app audio options only appear when the account setting allows them.
