OpenSSL Vulnerability - Zoom Meetings uses old version 3.1.1 | Community
  • November 26, 2023
  • 32 replies
  • 1 view
I raised this on the dev forum hoping it would have reached the right set of eyes.
https://devforum.zoom.us/t/zoom-5-6-10-vulnerabilities-with-openssl-dll-need-version-3-1-5/98806/1
However, following a Search all prior reports of vulnerabilities have been placed within Zoom Community.
Using Zoom Meetings Client 5.16.10 (26186)
Microsoft Defender flags as vulnerable for
CVE-2023-4807 CVSS 6.2,
CVE-2023-5363 CVSS 5.9,
CVE-2023-3817 CVSS 3.7,
CVE-2023-5678 CVSS 3.7,
Install source: https://zoom.us/client/5.16.10.26186/ZoomInstallerFull.exe?archType=x64
Detected files
c:\program files\zoom\bin\libcrypto-3-zm.dll
c:\program files\zoom\bin\libssl-3-zm.dll
OpenSSL Version 3.1.1.0
Recommended course of action, upgrade to OpenSSL Version 3.1.5 or 3.2.0
Updating to 3.1.4 would still leave CVE-2023-5678
https://www.openssl.org/news/vulnerabilities.html
CVE-2023-4807, Fixed in OpenSSL 3.1.3 (Affected since 3.1.0)
gitcommit see git openssl org/gitweb/?p=openssl.git;a=commitdiff;h=4bfac4471f53c4f74c8d81020beb938f92d84ca5
CVE-2023-5363 , Fixed in OpenSSL 3.1.4 (Affected since 3.1.0)
gitcommit see git openssl org/gitweb/?p=openssl.git;a=commitdiff;h=5f69f5c65e483928c4b28ed16af6e5742929f1ee
CVE-2023-3817, Fixed in OpenSSL 3.1.2 (Affected since 3.1.0)
gitcommit see git openssl org/gitweb/?p=openssl.git;a=commitdiff;h=6a1eb62c29db6cb5eec707f9338aee00f44e26f5
CVE-2023-5678 , Fixed in OpenSSL 3.1.5 (Affected since 3.1.0)
gitcommit see git openssl org/gitweb/?p=openssl.git;a=commitdiff;h=ddeb4b6c6d527e54ce9a99cba785c0f7776e54b6
Best answer by Frank_TB
Release notes for December 27, 2023
New and enhanced features
  • General features
    • Update to OpenSSL 3.1.4 - Linux, Android, iOS
      Due to the recently disclosed vulnerabilities with lower versions of OpenSSL, the Zoom client is updated to use OpenSSL 3.1.4. Depending on your network security configuration, you may also need to update your network infrastructure devices’ firmware.
      https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0073685
Regards,
We plan to upgrade to OpenSSL 3.1.4 in zoom client 5.17.5. Thanks.
OpenSSL 3.1.4 contains the vulnerability as well. A newer version than 3.1.4 will need to be implemented instead.
Hi all,
Release notes for the Zoom Client show that version 5.17.2 should be released in the next 24 hours.
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0073791
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0068823
January 8, 2024 version 5.17.2
General features
Update to OpenSSL 3.1.4 - Windows, macOS
Resolved Issues
Minor bug fixes
As they are only patching to 3.1.4 (but the commit in 3.15 could have been included).
Microsoft Defender flags will now only flag Zoom Meetings vulnerable for
CVE-2023-5678 CVSS 3.7.
We can now all await Zoom to update to OpenSSL Version 3.2.0
I don't know if the update to address this works properly. Now we are on Zoom version 5.17.5 and our users continue to experience major issues with Zoom just closing without any error code or commonality. Just randomly closes. As usual, Zoom Support is of no real help.
Tried the latest version and Using Zoom Meetings Client 5.17.5 (31030) (64-bit)
DisplayVersion 5.17.31030
Install source: https://cdn.zoom.us/prod/5.17.5.31030/x64/ZoomInstallerFull.msi
I can confirm that this version still utilises OpenSSL Version 3.1.4.0
C:\Program Files\Zoom\bin\libcrypto-3-zm.dll
C:\Program Files\Zoom\bin\libssl-3-zm.dll
Release notes
I know someone marked this as Solved, but it was not I (the original ticket creator).
OpenSSL 3.1.4 flags as vulnerable for
CVE-2024-0727
CVE-2023-6237
CVE-2023-6129 CVSS 6.5
CVE-2023-5678 CVSS 5.3
All have commits for 3.1.5 and 3.2.1
Zoom support has been pulling shady stuff lately. They likely closed this because they are getting too much negative attention. You can't trust Zoom to do the right thing.
No surprises here...
Tried the latest version and Using Zoom Meetings Client 5.17.7 (31859) (64-bit)
DisplayVersion 5.17.31859
https://cdn.zoom.us/prod/5.17.7.31859/x64/ZoomInstallerFull.msi
Release notes
OpenSSL 3.1.5 now has a fully final rollup for all the outstanding CVE’s
See openssl.org/source/
There should now be absolutely no reason not to issue an urgent roll-up from 3.1.4 to OpenSSL 3.1.5 or to OpenSSL 3.2.1
I opened a Zoom support ticket regarding OpenSSL 3.15 / 3.21
Zoom Support ticket TS0514340
Regards
Is there an update to when 3.1.5 or above will be implemented into the new Zoom installer?
This thread is marked as "solved" for 3.1.4 - but that version is still vulnerable.
This needs a Bump to not Auto-close its been unfixed since November 2023.
What is going on in the land of Zoom's Cyber Security?
Version 5.17.10 is now announced for upcoming release on the 26th of Feb yet the release notes state nothing regarding increasing OpenSSL dependencies.
When can the product expect a security fix?
ZoomVA
@lcchelpdesk The latest Zoom client utilizes security fixes addressed in OpenSSL 3.1.5 and is packaged with version 3.1.4. Since Microsoft Defender only detects OpenSSL 3.1.4 and not our custom fix, it outputs a warning. Once OpenSSL 3.1.5 is available as a stable release, Zoom plans to adopt this version into the Zoom apps and that change will be called out in our official release notes. Thank you to @Bort for researching this internally!
Thank you so much, VA for confirming the git commits were backported into the Zoom compile of 3.1.4.
From my post on the 1st of Feb, 3.1.5 was released in full on the 30th of January, hence PaulB10000 chase up with the same on the 14th of Feb and my last chase on the 22nd.
Now that it is confirmed, we can finally file an exemption against 3.1.4 for the current CVE's.
Thank you to all involved and still hope to see 3.1.5 in an upcoming release shortly.
