notification sound when someone joins/leaves | Community
I turned off notification sound when someone joins/leaves in settings online, but when i’m in a meeting on the app the notification sound continues. How can I turn this off?
    chrismenard7
    Hello. Try turning it off in the app. When you are in a meeting, open the Participant panel, click the three dots, and make certain Play Sound when someone joins or leaves is not checked. I added a screenshot.  If this answers your question, please click Accept as Solution.
    Now, in Zoom online, you indicated you turned off Sound notification when someone joins or leaves. You want to make sure it is off. Meaning not blue. I would update the Zoom app, which should sign you out, and then sign back in. I hope this helps.
    chrismenard7
    Is there a way to modify a recurring meeting so that there are no sound notifications when someone joins a meeting?
