Ray_HarwoodAnswer
Jul 30, 2023 4:26 PM UTC
Hi, @nic2.
Looks to me like you’re expecting more than one audio file, but you’ve provided a Screen shot of your Web Portal settings which indicate you want multiple audio for Cloud recording. You need to enable multiple audio files on the desktop Zoom app’s settings if you want this in the Local recording.
See the Recording section of the appropriate operating system section in this Zoom Support article for details on the Record a separate audio file of each participant option:
