Mar 5, 2025 10:06 PM UTC
Not receiving invitation links for meetings
When I schedule a meeting or accept an invitation to a meeting the invite shows up in my calendar but the invite doesn't include the link for me to cclick on to open the meeting. And I don't receive email confirmations for "My meeting"
Does anyoen else have this problem or kinwo how it can be resolved?
merimentAnswer
Mar 8, 2025 8:00 PM UTC
This sounds like an incorrectly structured ics file probably due to the integration between your calendar and Zoom. As a solution you can create the invite in your email calendar client and paste the link there. If you want to automate this there is a Zoom app, Salepager, for sharing calendar invites for Zoom meetings.
Mar 7, 2025 5:05 PM UTC
I am running into this same problem. I have been researching this and a lot of commenters are saying that you either have to buy the new scheduler or create the invites through Google/Link invitees to your calendar and/or contacts list. As we do these meetings for the Firm I work for, and that is breaking client confidentiality. Now if it is a plug in on your email (we use outlook) it suddenly works. Hopefully this helps.
djmorrisAuthor
Mar 7, 2025 10:41 PM UTC
Thank you! I updated Microsoft Word and that fixed the problem.
Dennis
djmorrisAuthor
Mar 7, 2025 10:39 PM UTC
Hi there,
Thank you so much. My tech person was here yesterday. First he tried to link Zoom to a Gppgle calendar and that didn't work. Then we updated Microcoft Word which was the 2006 version. After he did that everthing is running ok. I appreciate that you took the time to share your insights.
Best,
Dennis
www.acaedmicleadershipprogram.com
Feb 24, 2026 3:35 PM UTC
I just had this problem and saw this while searching for solutions.  I found a solution that worked for me so I thought I’d come back here an post it for others as well.  Zoom has a setting when one schedules meetings that for me for some reason was set to “Offline”.  I clicked on it and changed it to “Zoom meeting” and not only did it work it automatically sent out an update to all invitees and re-sent the invitation this time with the (hopefully correct!) link for the meeting that I had scheduled.  Hope it works for you as well!
merimentAnswer
Jul 7, 2025 5:14 PM UTC
Me, too.  I registered for three different meetings this week from three different organizations and have received NO link to any of them.  My Microsoft 365 is current so that shouldn't be an issue.  What's going on?
Aug 4, 2025 8:25 PM UTC
I scheduled meetings and some invitations did not receive the email link in blue.  Just the words and numbers.
