No zoom audio output from chromebooks | Community
Participant
February 8, 2023
  • February 8, 2023
  • 23 replies
  • 450 views
I have installed the Zoom PWA on three different chromebooks and there is no audio output using zoom on any of them. The discontinued app used to work fine. Unfortunately this app is completely useless to me.
    Best answer by daleb
    I thought my problem was Zoom PWA only, but I tried Google Meet and experienced the same problem. It turned out in my case, that a Chrome extension disabling html5 auto-play was blocking audio from these particular apps. Adding exceptions for meet.google.com and pwa.zoom.us in this extension allowed sound to come thru. I haven't tried an actual meeting yet, but I can at least do the speaker test from within these two apps and actually get sound! I will update the next time I try a meeting.
    Step 1: Restart the Chromebook.
    Step 2: Reset your Settings. Open Chrome.
    Step 3: Remove your Profile.
    Step 4: Uninstall Apps and Extensions.
    Step 5: Audio.
    Step 6: Check your WiFI.
    Regards,
    John
    dalebAuthor
    Participant
    February 8, 2023
    Well, thanks for the reply. Not sure what these instructions mean. It sounds like you're suggesting resetting or removing just about everything on my Chromebook. In particular, what does #5 mean? Audio isn't a verb,
    Hope you have tried the Audio Settings already:
    https://support.zoom.us/hc/en-us/articles/4568819394573
    Have you tried using Zoom PWA in incognito mode. Some users have found success doing that. Can you try that if above does not work.
    https://community.zoom.com/t5/Meetings/No-audio-on-Zoom-for-Chrome-PWA/m-p/67735
    dalebAuthor
    Participant
    February 8, 2023
    Thanks for the response. Yes I've tried the audio settings. The only option is to change which speaker, but since I only have the internal speakers, there is nothing to change. I'm not sure how to use incognito mode when using thís app. Maybe I don't understand something, The process I've used is to open the pwa, navigate to my contacts, select one and choose to meet, I think I get a launch meeting popup, the meeting pops up, video is ok, they can hear me but I can't hear them. Where does incognito come in?
    Hi @daleb Google Chrome has an "incognito window" mode. This is a screenshot on my MAC taskbar
    I too have absolutely NO audio on Zoom on my chromebook.  It is currently on Chrome PWA for Zoom.  Volume all the way up.  Always workde last year!
    dalebAuthor
    Participant
    April 27, 2023
    Yeah we resort to calling and using phone audio when we zoom to my daughter but that is a limited workaround.
    It used to work in the past.  Whatever they changed removed all audio.
    Check Your Audio Settings
    Right-click on the speaker icon in your taskbar and select Sound Settings. Make sure you're using the right output and input devices. Slide the master volume slider all the way to the right. Then run the master volume and microphone troubleshooter
    Regards,
    Will
    Regards,
    Will
    hey i was facing the same issue when it was attached with third party device, actually i was conducting lecture with my students and i was using earpods attached with bluetooth in my laptop and i was facing grag audio as well as the recieving we all perfect. is it any error in zoom or third party device.
    I am having the same problem with the Zoom PWA on my Chromebook: no audio!  Used to work fine with the ChromeOS app.
    My solution: Give up on Zoom!  Switch to Google Meet.  I am instructing all my meeting hosts to do likewise, if they want to meet with me.
    Try removing all chrome extensions related to the computer audio. Then reset zoom settings and reload the app or website. That worked for me.
    dalebAuthor
    Participant
    August 22, 2023
    Hmm, I have no extensions related to the computer audio. I may try switching to  Google meet as suggested above.
    dalebAuthorAnswer
    Participant
    September 19, 2023
