Nov 10, 2022 10:23 PM UTC
No Sound When I start Recording
I'm using a MacBook Pro and a Blue Yeti Microphone
When I start my meeting I check my sound and make sure everything is working properly, but once I start RECORDING after a little while a message pops up asking me if I want to connect my sound. This disrupts my recording and although I go through the steps and by all the "tests" everything is working, after i end the meeting and go to replay there is NO SOUND.
Everything is connected properly. The Mic works fine in all my other programs. Something is wrong with ZOOM and is very frustrating.
Nov 11, 2022 10:10 AM UTC
Restart your PC. First things first, restart your computer to solve the Zoom recording no audio problem. Believe it or not but this simple step fixes the issue almost 80% of times. It refreshes the system and removes any minor glitch that may have interfered with Zoom audio.
Hope this helps,
James
Aug 7, 2023 1:21 AM UTC
Did you find the answer? I am using an IPad Pro with same issue.
