no sound in zoom -
I can hear, but they can't hear me
I'm wondering if it is connected to the Mac upgrade yesterday?
    Check if the microphone, speakers, or headphones are plugged in and not muted. Unplug the device, then plug it back in. If it's a bluetooth device, ensure that it is turned on and connected properly. Make sure that you are using a supported USB device for Zoom.
    Regards,
    James
