No sound
I am starting my meetings but for some reason no one can hear me. Started suddenly.
    IP-Man
    @AnyaBell
    You could try a clean removal/uninstall of Zoom Application and then reinstall it again. This is to ensure that any corrupted files/config on the application is all completely removed before reinstalling.
    If you have a Mac - try uninstalling Zoom by using their uninstall file instead of putting the Application in the trash.
    You can do this by going to Applications -> right clicking on zoom.us -> Show package contents -> open Contents -> open Frameworks -> use the ZoomUninstaller file.
    After this, try to reinstall Zoom again.
