Jan 19, 2024 4:26 AM UTC
Need to upgrade both 32 and 64 bit zoom application when we installed on 64 bit machine
we have query regarding Zoom application .
when we tried to install both 32bit and 64 bit zoom application in 64 bit , one of the 32bit or 64 bit is getting removed  from the machine.
we need a solution where both 32 bit and 64bit needs to be installed in a single 64 bit machine .so if want upgrade only 32bit , 32 bit should be upgraded with the newer version and 64 bit remains same with the version and 64 bit shouldn't be removed from the machine
And when we tried to upgrade 64bit ,64 bit should be upgraded with the newer version and 32 bit remains same with the version and 64 bit shouldn't be removed from the machine.
Team Please can you help with your inputs here
