Need Help Calendar Scheduling | Community
  • April 25, 2023
  • 35 views
Trying to have clients go to a scheduling calendar (does Zoom have this?) and sign up for a Zoom appointment. Is this possible?
    Hi @DB25
    Yes You can integrate your calendars and it is the preferred method of scheduling / attending meetings. Here are the steps:
    https://support.zoom.us/hc/en-us/articles/360000488243-Using-calendar-and-contacts-integration
