Mar 17, 2022 7:24 PM UTC
My Zoom does not connect when I use wi-fi at home.
I have this weird problem, that I can not start zoom, when I am connected to WI-FI at home. The internet connection is good, as everything else works but Zoom. The browser can not open any file or page that is about Zoom. It would work with mobile net if it was stable enough. Can somebody have an idea what the problem is, and how can it be solved? By the way the firewall is not a problem. with  or without firewall, Zoom does not come through. Thank you!
    Mar 17, 2022 8:51 PM UTC
    @evakovacs Is this issue the same for all machines (laptop, smartphone, tablet) connected to your home wifi when you try to access Zoom services? Is there any active VPN connection running on your machine or home wifi/router? If there is, can you please try to disconnect from VPN session and try to connect to Zoom or access Zoom web pages. Do you have security endpoint protection on your laptop/machine (like Symantec, TrendMicro, ESET, etc) ? Try to temporarily disable it too and see if you are able to connect to Zoom.
    When you use the same machine/laptop to an internet connection other than your home wifi, are you able to connect or use Zoom services?
    Having answers to those questions will help us narrow down the issue.
    evakovacsAuthor
    Mar 21, 2022 8:35 PM UTC
    @zac2021  Thank you for answering me so quickly. As I still can't open any Zoom related file or page, I had to wait for an opportunity to connect an other wifi than my own at home. As you see, the problem still stays and yes, it is the same on each and every device we have at home, and it is not because of my Zoom account as my husband can not use his own account either.
    I do not know what happened on 10.03, Thursday evening. I have used Zoom from the same wi-fi and location for 2,5 years, but never had any problem.
    I have disconnected, restarted everything I could, even reinstalled the app, updated both my phone and my macBook. Nothing works. I do not know of any VPN sessions, even disabled firewall. Nothing!
    I am able to connect and use Zoom services on all my devices being connected to an internet connection other than my own wifi. This led me to the conclusion that it is not my phone/laptop or my account, but my wifi connection.
    I need to mention here, that I received an email from the Zoom Team, in which I was told, that an unusual sign-isn was detected from a device or location I usually don’t use. I had to enter a code to sign in.
    This happened on the day when the problem started.
    I contacted the Zoom support team via an email address I have found here in one of the answers sent to someone else is a related problem.
    Mar 23, 2022 5:20 AM UTC
    @evakovacs Thanks much for sharing more details. It seems that issue is isolated to your wifi connection/home connection. I would assume also that the same issue is experienced when you tried to connect one of your laptops directly to your home router (hard-wired, LAN connection). Since you mentioned that you can connect to Zoom services when connected to other connection except for your home wifi, I would also suggest contacting your home Internet Service Provider (ISP) and check with them if they see any Zoom traffic originating from your home network that are getting blocked by the ISP network. This is rare but it is worth checking with your ISP.
    Would you mind also sharing the Zoom support ticket number, if you have one. If you haven't logged any Zoom support ticket yet, you can do so here.
    Sep 26, 2024 8:54 AM UTC
    Same issue with my connection today.  I can acess everything online, FB, gmail, yahoo, etc. via my home wifi but not Zoom or any Zoom webpage.  I have to tether my laptop to my cell internet and then I can access Zoom on my laptop.  What's up?  Seems we don't know yet...?
    Sep 26, 2024 8:59 AM UTC
    Okay, seems there may be a techie thing to try or contact my internet provider about someone using my internet...and yes, the other day I had to veryify who I am with Zoom for a secondary Zoom account on this laptop...it may not like two zoom accounts on one laptop...plus, I will need to open report with Zoom.  Will do.
    Sep 26, 2024 9:11 AM UTC
    I have a free zoom account so i can't get help other than here.  Hope someone finds a solution.
    Sep 26, 2024 11:39 AM UTC
    I'm twg, twg1...I tried again to get to a Zoom web page via home wirless after I cleared my cache and restarted...it didn't work...then I went to a Zoom web page again and this time ran that diagnostic option...it said my computer had no problem and it was the Zoom page...and then when I tried to access my online Zoom account, I got in!  And then I got into the Zoom app on my laptop!  What a headache...don't know if either was the soution but for now, Zoom works via my home wifi again.
    Dec 1, 2024 9:40 PM UTC
    I am having this same problem, does anyone have a solution? Everything works but Zoom and Canvas on my home wifi. It was working just perfectly a week ago. My wifi is working flawlessly with everything else. Help please!
    Dec 16, 2024 8:23 PM UTC
    I too have been unable too get Zoom to work on my home desktop.
    Still looking for a solution.
    Nov 26, 2025 2:49 AM UTC
    SOLVED
    I had the same issue. Devices connected to the internet via my home wifi (tested on multiple laptops) all were unable to connect to Zoom both through the app and the browser could not open any page about Zoom. The same devices however worked fine with Zoom when using a hotspot.
    I contacted my network provider who eventually dispatched a technician. The Technician assisted me with disabling IPV6. Once IPV6 was disabled, I could connect to Zoom again.
    I hope this helps!
    and contacted my network provider repeatedly.
    Mar 11, 2026 11:24 PM UTC
    Same issue and same solution worked.  Thanks.
    tom cary
    Contributor I
    Contributor I
    Mar 12, 2026 2:18 AM UTC
    Hi! This sounds like it could be a network or DNS issue specific to your home Wi-Fi. A few things to try:
    1. Flush DNS – On Windows, run ipconfig /flushdns in Command Prompt; on Mac, use sudo dscacheutil -flushcache.
    2. Change DNS servers – Try using public DNS like Google (8.8.8.8 / 8.8.4.4) or Cloudflare (1.1.1.1).
    3. Check router settings – Make sure Zoom domains aren’t blocked and that ports 80, 443, 3478–3481 are open.
    4. Test with a different network profile – Temporarily create a guest Wi-Fi or hotspot to see if Zoom works there.
    5. Reinstall Zoom – Sometimes leftover settings can conflict with network detection.
    If none of this works, contacting Zoom Support with your network logs can help pinpoint the exact cause.”**
