Mar 3, 2022 1:22 AM UTC
My PC speakers & microphone are working, however, zoom audio is not working
Have been using zoom for years, with no issues. Suddenly ( for approx 1 week), I have no speakers or microphone on zoom. Both are working well on my PC.
How can i fix this, please?
    Mar 3, 2022 3:51 AM UTC
    @2939 , I am sorry to hear about your issue.  Do the speakers and microphone show up on your computer when you check the audio settings?  Do they show up in the Zoom Audio settings? When is the last time you rebooted?
    Jul 28, 2026 11:14 PM UTC
    yeah they show up and none of them work it just keeps saying they don’t work I rebooted just now didnt help
    Mar 3, 2022 8:11 AM UTC
    @2939
    Step 1: Right-click on the volume icon on the taskbar and then click “Open Sound settings” to open the Setting dialog.
    Step 2: click “Sound Control Panel” to open the Sound dialog.
    Step 3: Under the Playback or Recording tab, right-click on your speaker/microphone and then click Properties. You should now see the Speakers/Microphone Properties dialog.
    Step 4: Under the Advanced tab, you can see a checkbox shows “Enable audio enhancements“, please check or uncheck the Checkbox as your need.
    If the “Enable audio enhancements” option is missing, it’s likely because your selected microphone/speaker doesn’t support them.
    Notice: There is a known freeze issue caused by Dell’s new audio driver, in order to fix this issue, please make sure that all the audio device’s(both microphones and speakers) “audio enhancements” feature are disabled, not only the current used device.
    Jul 26, 2026 4:46 PM UTC
    I am having the same problem as all these people, nothing that you said works. I am not using a bluetooth speaker even just the macbook speakers which work with everything but zoom meeting. I’ve tried changing speakers connecting different ones and messing with all the settings and updating and reinstalling to the latest version
    Oct 5, 2022 4:33 PM UTC
    I have tried all of these. Zoom lists my devices as options but gives an alarm that says they are not working. They are working with all other programs. I have rebooted twice. I have tested them with four other programs. It is clearly a Zoom issue. I have a call in 30 minutes. What is the solution, other than switch to Teams?
    Nov 3, 2022 12:57 AM UTC
    I have an identical problem.  The speakers work and microphone work even in Zoom - I can test them before a meeting. - but as soon as I click 'Join computer audio' they don't work.
    Nov 3, 2022 1:02 AM UTC
    Zoom evidently is still stuck on a default bluetooth headphone that I used to have listed.  I  have removed it and switched off Bluetooth but still Zoom will not use my speakers.
    Jul 30, 2026 7:04 AM UTC
    Many apps will use the default audio resource; however, Zoom is designed to allow direct selection of an audio resource when multiple resources are present for mic and speakers. Zoom does use the default audio resource for computer audio sharing. So be sure the correct audio device is properly selected in Zoom, that is not exclusively linked to another app, and is not being used by a background app. Personally I have a lot of audio resources on the computer and can run a Zoom meeting while monitoring up to 4 other Zoom meetings all at the same time on one computer without any audio issues.
