my mic does not connect when using a speaker | Community
  • February 15, 2023
  • 24 views
please add mic connection with speakers because all the time my sound is short-circuited I use a speaker but when I talk no one can hear me
    Make sure the cable connection with the microphone is fully inserted into the appropriate port. If Zoom fails to detect your microphone, unplug the device and plug it back in. If it's a bluetooth device, ensure that it is turned on and connected properly. Make sure that you are using a supported USB device for Zoom.
