Oct 19, 2022 11:35 PM UTC
Mobile "None" Virtual Background and/or Filter not working
A pink virtual background or filter is on my Android mobile app, and will not go away.
I have uninstalled the app and reinstalled the latest version, to no avail.
Choosing different backgrounds or filters does work reflects each new selection.
However, choosing option "None" does not remove what seems to now be a default pink background.
Interestingly, the "None" option works when switching to the forward camera.
So, I can use my phone if I am comfortable not seeing anyone else nor seeing where I am in the shot.
The "selfiecam" attached images show the pink background and the "Virtual Background" and "Filters" menus - both with the "None" option selected.
The "forward" image shows that the pink background goes away when the other camera on the same phone is in use.
Phone: "Galaxy S20 FE 5G"
Model: SM-G781U1/DS
One UI Version: 4.1
Android Version: 12
Kernel: 4.19.113-24328540
Zoom: 5.12.2.9059 (previous version also had same bug)
    Austin12Answer
    Aug 27, 2024 6:58 PM UTC
    Hello.  This is actually a Samsung feature called 'Video Call Effects'.   You can turn it off by swiping down from the top of your screen when in a Zoom Meeting, tapping on 'Video Call Effects', and setting the background color to 'none'.
    Nov 27, 2022 12:02 AM UTC
    I have the same problem on the desktop app. I too, cannot get rid of the pink haze.
    Feb 29, 2024 12:22 AM UTC
    Same!! So annoying. It's just with this last update I believe. HELP ZOOM... WHY?
    Jun 21, 2024 1:26 PM UTC
    Same problem here.  Pink background looks ridiculous. Not a problem on my laptop, same Zoom account.
    Android version 14
    Galaxy Samsung S22+
    Jul 19, 2024 3:36 AM UTC
    Same here. Anyone find the fix? Or is it a bug we have to wait to be fixed?
    Austin12Answer
    May 3, 2025 9:43 PM UTC
    This was so helpful!  I had a Christmas Tree somehow setup and could not remove that for the life of me.  Thanks for posting the solution!
    Nov 26, 2024 4:35 AM UTC
    This solution worked. I had this issue for whatsapp and zoom video calls. The above solved the issue. Thank you so much
