Aug 6, 2025 4:01 AM UTC
Missing “Original Sound” Option on Galaxy Note10+ (Zoom 6.5.7)
Hi everyone,
I used to regularly enable Original Sound during meetings on my Samsung Galaxy Note10+, but with recent Zoom updates (currently on v6.5.7), that option seems to have disappeared.
The toggle for “Use Original Audio” is still in my app settings under Meetings → Audio, and I have it turned on.
But once I join a meeting, the “Enable Original Sound” option no longer appears under the “More” menu.
I’ve already updated, restarted, and reinstalled the app — no luck.
Has anyone else run into this? Is there a workaround, or did Zoom officially remove this feature for Android users?
Thanks in advance for any help!
ExpertswhoJohn
Aug 8, 2025 9:15 PM UTC
hi @LaniD1 ,
Things have moved around
Click on the top left where your profile picture is.
That is like your profile page
At the bottom is your settings option
Then there is an audio tab with original sound.
Hope that helps
John
