Nov 8, 2021 8:54 PM UTC
Microphone works fine, then fails
I have a problem running a zoom meeting.  The meeting starts perfectly with the selected microphone and speakers all 100% functional.  I am using a Windows 10 (now 11) desktop with 32GB RAM 3TB SSD and ethernet link to my WLAN-Router.  During the meeting at intermittent frequencies, my microphone becomes unavailable within Zoom.  Nothing has changed, no other app has been initiated, no other app is running in the background.  Zoom advises in a comment in the bottom left hand corner of my screen above the Audio section shown with a microphone image:
"Your microphone is not working. Please check your connection or use a different mic."
What I do to solve this problem is to click on the dropdown list of the Audio to the right of the microphone image, select the mic I was using and and then functionality is restored for a while, duration variable.
This happens whether I use the microphone on my Logitech Streamcam or a DUAL conference mic wired into the microphone slot at the back of my unit. This is definately a software problem, the microphones are all correctly plugged in and authorised to Zoom usage.
Please advise.  I am about to purchase a full licence for meetings with 3 or more people, and I don't know if it will be worth it!
    Brett1Answer
    Nov 16, 2021 8:25 PM UTC
    This is an update for anyone else who might get this problem.
    Based on the advise of an engineer at the supplier of this machine, I performed a Windows system reset.
    Problem solved.
    Brett 😊
    Brett1AuthorAnswer
    Problem solved.
    Brett 😊
    Nov 17, 2021 5:31 PM UTC
    Thx for the advice!  I’ll try this to do windows reset- hope that goes ok cause I have no idea what that entails!  My kids zoom
    classes work 50% of the time with sound microphone.  Wish zoom just came out and warned the community about this.  Middle schoolers need to use their voice!
    Nov 17, 2021 5:43 PM UTC
    Also… does windows just mean windows restart?  Of does this mean windows factory reset?
    ZoomVA
    Nov 16, 2021 10:21 PM UTC
    @Brett1 I'm so sorry your original post didn't have a reply yet, but thank you very much for taking the time to come back to the Zoom Community and share the solution that worked for you! This is sure to help other Community members and we really appreciate it! 😊
    Dec 18, 2023 4:40 PM UTC
    I have a similar problem but with brand-new otherwise Bose headphones connected via Bluetooth to a MacBook Pro running MacOS Monterey 12.1. Zoom audio settings are correct and the sound checks are perfect. After 15-20 minutes the other Zoom participants hear a crackle from my mic, this gradually gets worse and worse until I leave the meeting. I log straight back in again, the sound is then immediately clear, but only for 15-20 minutes. Zoom seems to 'get tired'! This is hugely frustrating. Would it help if I cable them together? From the above comments it sounds as if it won't. My current workaround is to try using the Bose headphone only as Speakers and the Built-in Internal Microphone as the Microphone. But it shouldn't have to be this way. Any help welcome.
    Feb 8, 2024 7:16 AM UTC
    Waiting for this answer, bose qc 45 macbook air m1 2020.. microphobebin headset works poorly
