Nov 25, 2024 3:18 PM UTC
Microphone input audio sounds robotic
I've been having an issue for a little over a week now that I can't seem to resolve.  When on Zoom, my input audio sounds robotic with a bit of static. This only happens in Zoom and not on OBS or any other recording software that I use. This also happens with both my audio interface setup and USB-based microphones.
I'm on a Mac M-based computer currently running Zoom v6.2.10. I have uninstalled and reinstalled multiple times. I have a high quality interface and XLR-based microphone setup that sounds perfect everywhere else. I have tried using other high quality USB-based microphones and the only devices that do not sound different than other recording software are my Apple AirPods and AirPods Max's.
I have tried changing the audio settings to nearly all variations of Original Sound for Musicians and Zoom Background Noise Removal. Nothing seems to fix this issue.
What else can I do to fix this issue?
Contributor I
Nov 25, 2024 5:12 PM UTC
Sounds as if that mic is being shared by some other device at the same time as Zoom. Just make sure that OBS is not running when you test Zoom.
I would start from there. The next option would be to change the cable you are using to connect the audio sound card and USB mics to the mac - or try a different USB port!
And then finally reinstall the USB audio device driver on the Mac. The AirPods are using Bluetooth, so do not go through the USB driver.
cobeyAuthor
Nov 25, 2024 6:03 PM UTC
I've fixed it! A recent update must have reset my Mic Mode on Apple to Voice Isolation which was causing the issue. I changed it back to Standard and everything works now.
