Apr 23, 2023 10:24 PM UTC
microphone and camera test
Could, pls, somebody tell me how I can test my microphone and camera BEFORE I start a conference? I have just installed zoom. After the installation there was some kind of a test. The camera seemed to be working, but the microphone did not. I clicked my profile, but it did not have any settings. I have only a basic account. Thank you.
    Apr 26, 2026 10:30 PM UTC
    same question
    Apr 29, 2026 7:29 AM UTC
    select settings from the profile icon
    Apr 29, 2026 12:08 PM UTC
    You can prepare for upcoming Zoom meetings by setting up a Zoom test call. Within your test meeting, you have the ability to check your internet connection, familiarize yourself with Zoom's video conferencing features, and adjust your audio and video before joining the meeting.
    If you don't have time before joining, you can also test your video or audio while in a Zoom meeting.
    How to create a test video call
    1. Open the Join Meeting Test page.
    2. Click Join to launch Zoom.
      You will be redirected to launch the test meeting:
      • If you have the Zoom desktop app installed on your computer, click Open Zoom Meetings to launch Zoom.
      • If you don't have the Zoom desktop app installed on your computer, click Download Now to download, install, and then run Zoom.
      • If you cannot download or run the Zoom desktop app on your computer, click Join from your browser.
      The test meeting will launch.
    3. Follow the on-screen prompts to join the meeting and test your video, audio, and microphone. Once the test is over, you will join the test meeting as a participant and can use it to familiarize yourself with the meeting participant controls available to you.
      Note: If you're having trouble seeing or hearing yourself or the ringtone, learn how to troubleshoot common audio and video issues.
    Join a Test Meeting
    Regards
    New Member
    Aug 27, 2026 3:06 PM UTC
    Can't find my voice check
    YaBoiB
    Aug 27, 2026 3:34 PM UTC
    ​@Rebecca Snipes ,
     If you are already in the meeting and you want to check if your microphone is working. Next to the microphone on the bottom left corner there is a carrot. That is what we call it, but it is just the top part of an arrow pointing up  ^ <--- like that. When you click on it you can choose audio settings, and it is the same as when you are in the Zoom Desktop client settings, it will have all of the same components that you can check on. Audio, video, general settings, etc.
    Let me know if that was helpful for you.
